2 Pages12>
uglystik
#1 Posted : Monday, June 4, 2012 5:06:57 PM(UTC)
uglystik
Maytag Dishwasher Wont Start , Lights Only Work On Right Side Of Control Panel
#2 Posted : Thursday, June 7, 2012 2:46:34 AM(UTC)
Your profile shows you also had a problem with this unit back in 09.
How did you fix that as it sounds similar?
uglystik
#3 Posted : Thursday, June 7, 2012 3:29:16 AM(UTC)
uglystik
REPLACED CONTROL PANEL, could see bad conductors in ribbon wire , this is different machine, wires look good ,just out of warranty. control panel or board? thanks
#4 Posted : Thursday, June 7, 2012 3:47:25 AM(UTC)
I cannot find this unit at AppliancePartsPros.
They probably have the parts but the unit is not on the customer inquiry system yet.
I am having problems trying to upload so will try later.
You may have it or it may be taped under the unit or to the back of the kick plate.
I cannot say which device is the problem.
Look at the tech sheet and check for common tracks/lines for the keys that do not work.
May be dirty contacts so my reply to your old unit post may apply.
The normal way to troubleshoot this is to check the keypad outputs with a meter. Then if it checks out OK replace the control board. Still a bit of a crap shoot but your odds are better.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
#5 Posted : Thursday, June 7, 2012 1:58:16 PM(UTC)
Still cannot upload the tech sheet but I will keep trying.
#6 Posted : Thursday, June 7, 2012 5:01:01 PM(UTC)
Still cannot upload it so will try a different way.
Here is a link to it.
Download MDB7749.pdf
uglystik
#7 Posted : Thursday, June 7, 2012 7:37:05 PM(UTC)
uglystik
thanks for your time i got download , will be back for parts
normfm
#8 Posted : Monday, June 18, 2012 10:53:43 AM(UTC)
normfm
I have a maytag dishwasher model#mdbt609awb2 when I try to start it I can enter the wash cycle and the lights on the diplay come on but when I try to enter start it will not let me, the light for start does't even come on. Then after about 15 seconds all the lights go off. Help.
uglystik
#9 Posted : Monday, June 18, 2012 12:54:40 PM(UTC)
uglystik
denman has download on this page for tech sheets and trouble shooting guide . check wire from control panel to board for bad conductors, wiring ribbon is part of control panel,
MDB9600AWW dishwasher
#10 Posted : Thursday, June 28, 2012 7:18:19 AM(UTC)
My Maytag MDB9600AWW dishwasher won't start either. The lights come on for the options and the 2hr on the front. But neither the start or delay buttons depress or work. I opened the control board and nothing looked fried.
I put in a new handle and switch and it still doesn't work. Could I have put the wires back on incorrectly? They fit on both ways, I went with where the wires naturally laid. I found a picture with the black wires on the left (if facing the dishwasher). How do I know if these are correct?
Guest (6)
Maytag Dishwasher wont start (Dishwasher Repair)
by EvieHunter 8/9/2012 11:18:24 AM(UTC)
maytag dishwasher wont start (Dishwasher Repair)
by maytagdog 4/16/2012 8:36:47 AM(UTC)
by timbucktoo 8/31/2011 9:40:40 AM(UTC)
Maytag dishwasher wont start (Dishwasher Repair)
by lmfalk 2/17/2011 11:16:55 AM(UTC)
by uglystik 11/7/2009 12:01:29 PM(UTC)
2 Pages12>
