wing63
#1 Posted : Tuesday, June 5, 2012 7:00:26 PM(UTC)
wing63
When my dryer heats up, the top gets very hot and the main circuit breaker trips. If I use the dryer with air only (no heat) it runs just fine. I have narrowed it down the the themal cut-off switches or the blower thermostat. Anyone help as to which one would cause the breaker to trip.
#2 Posted : Wednesday, June 6, 2012 2:34:51 AM(UTC)
Replacement parts for Whirlpool LEQ9508PW0 29"ELECTRIC DRYER | AppliancePartsPros.com
I doubt it is a thermostat because it has not blown a thermal cut-off or fuse.
But you did not say how you diagnosed it as a thermostat.
A more likely cause culprit is the heating coil being grounded.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and draw too much current.
It would also be a good idea to check/clean your vent system.
Also check/clean the blower wheel.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LEQ9508.pdf (261kb) downloaded 14 time(s).
