I have model ED5RHAXNQ00 and the interior looks different from your picture. I can't tell from the manual diagram how the spring fits. I am not even sure if a part is missing but cannot determine where the pin that runs through the spring fits on the right.
Whirlpool Model #GD5SHAXMB00 Side by Side Refridgerator/Freezer. I am not sure if I have the same issue as the original post, but I have taken the panel off of the ice/water dispenser area because my ice dispenser quit working...suddenly. As I pull the cover back, a small piece of plastic somewhat similar to a toothpick falls to the ground and notice a black "switch" dangling. It appears that the plastic piece is/was a support for the switch that activates the auger to dispense the ice. I pushed the button and it does work. So, what I am wondering is...the part number below the correct kit for this type of repair? I copied and pasted the number from another post which also had a "chute kit" part number. :confused: After looking at both part number details, I am a little confused as to which parts I need. Your help is greatly appreciated!!! Part Details - WHIRLPOOL Ice door kit, part number: AP3595356Thanks, Greg
Model KSRX25ftss00
My dispenser parts look similar to the parts in this thread. I can't figure out how to get the front door cover assembly off to diagnose the problem. It seems to be clipped at the top & bottom. I fear I will break it. Any suggestions on how to remove?
The spring has fallen out & the flapper will not close.
my tab broke also and i lost the plastic that broke so i shaped a new piece of plastic and used plastic epoxy to apply n prob solved
The spring has fallen out & the flapper will not close. pull the water tray out and you will see 2 screws remove then lift up it the top has tabs that sit in holes if you need anymore help i can guide you through taking the electronic panel off if needed
I have the same issue... I think.
but I have a white fridge. does anyone know the part number for a white fridge?
thanks in advance
I have a broken door too. but my fridge is white. does anyone know the part number for a white door? or can I use my old white door?
