tommy cochran
#1 Posted : Tuesday, May 29, 2012 11:34:35 AM(UTC)
tommy cochran
I know i have aclogged drain tube but can't run anything down it
Simon / APP Team
#2 Posted : Tuesday, May 29, 2012 12:02:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If your drain line is frozen and clogged remove the rear panel in the freezer and clear the ice from the bottom of the pan.
Then, using the blow dryer and hot water melt the ice blocking the drain.
Be patient, it may take more then a few minutes.
It helps if you can use the plastic tubing to clean the drain.
Thank you. Post the results.
Simon.
tommy cochran
#3 Posted : Tuesday, May 29, 2012 12:22:00 PM(UTC)
tommy cochran
all the ice is out but? there must be some dried stuff in tube i can not run anything down it:rolleyes:
Simon / APP Team
#4 Posted : Tuesday, May 29, 2012 12:28:54 PM(UTC)
Simon / APP Team
Groups: APP Team
Get the 1/4" plastic tube and try to clear the drain from the bottom up.
Compressed air the best if you can get it (careful not to over pressurise the drain.)
