cdwilson
#1 Posted : Friday, March 27, 2009 8:04:50 AM(UTC)
cdwilson
I have notice that every couple of days I have water on the floor in front of my side by side unit. There seems to be water freezing in the bottom and then running out onto the floor. I do not see a drain inside. How can I fix this on my own?
woodchuckie
#2 Posted : Friday, March 27, 2009 9:28:00 AM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
water leaking on floor (Refrigerator & Freezer Repair)
by capetish 8/23/2015 6:39:00 PM(UTC)
water leaking on floor. cannot find drain pan (Refrigerator & Freezer Repair)
by stanbrook1 7/5/2011 12:41:50 PM(UTC)
front loader major noises during spin, water leaking on floor (Washer Repair)
by joeblue 5/22/2011 9:14:11 AM(UTC)
Water leaking on floor (Refrigerator & Freezer Repair)
by jimzilla 6/26/2010 9:09:49 AM(UTC)
