creeker69
#1 Posted : Thursday, May 24, 2012 6:51:55 PM(UTC)
creeker69
Rank:: Member
MDG5500AWW model Neptune Maytag Gas Dryer. Ignites fine when cold but does not stay warm. It starts out fine, but soon gas shuts off and does not re-ignite. This happens on sensor dry setting or timed setting.
I check the vent on the outside of the house and flaps on vent are extended (open) when dryer is running so I do not suspect a clogged vent. Well, at least I know it is not totally clogged.
Any ideas? Thanks in advance....
Ron
ApplianceJunk
#2 Posted : Thursday, May 24, 2012 8:21:45 PM(UTC)
ApplianceJunk
Hi,
I would suspect the coils on the gas valve are at fault and need to be replaced.
Your model uses gas valve coil, Part number: 279834
creeker69
#3 Posted : Friday, May 25, 2012 5:28:15 PM(UTC)
creeker69
Rank:: Member
Originally Posted by: ApplianceJunk Go to Quoted Post
Hi,
I replaced the coils tonight. Igniter glows, ignites the gas, it burns for a little bit, then goes out. If it continues to run, it will reignite but only burn gas for about 5-10 seconds and then goes out.
