I have a door handle for my Amana freezer, that is loose and comes off. One of the clips that holds the handle on is broke. Do I need to replace the whole handle or can I just get the clips?
Groups: APP Team
Hi. According the diagram you can replace the clip only if you are sure that the handle is not broken. The clip Part number: 67007059
That part doesn't look like the one I would be replacing. How does it attach to the door?
Groups: APP Team
my freezer door has 2 screws in the door, the handle has 2 clips, with a hole and slot in each, the screws extend into the holes and the handle is slid to the left to lock on. One of the clips is broke.
