chocomom
#1 Posted : Wednesday, May 16, 2012 6:12:41 AM(UTC)
chocomom
Both the fridge and freezer are not coming down to temp...both is slightly cooler than room temp. Checked the compressor and there is no leaks only lots of dust.
Light works and can hear the fan running.
Manufactured in 08/04.
Thermostat? freon? Thanks.
#2 Posted : Wednesday, May 16, 2012 4:15:32 PM(UTC)
The first thing you may want to do is remove the rear cover and the bottom front grille and clean the condenser coils. Then wait about 24 hours and check the temperature, using a good refrigerator thermometer. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool ET8MHKXMT00 REFRIGERATOR | AppliancePartsPros.com
chocomom
#3 Posted : Tuesday, May 29, 2012 1:50:44 PM(UTC)
chocomom
Hi Gene,
Tried what you suggested and there is no changes. Any other suggestions?
Thanks.
#4 Posted : Tuesday, May 29, 2012 2:07:15 PM(UTC)
Did you measure the temperatures? Did it changed after cleaning?
Does the compressor work?
Do the fans inside the freezer and next to compressor work?
