asheborosoccerdad
#1 Posted : Monday, March 10, 2008 6:25:06 PM(UTC)
asheborosoccerdad
my vent fan just stopped working, the display says the fan is on but nothing happens.
#2 Posted : Tuesday, March 11, 2008 2:00:15 PM(UTC)
The problem could be a bad fan motor or a bad control board.
Perform the troubleshooting as described in the service manual (pages 7 & 10).
- The part number for the control board is AP3951232
- The part number for the fan motor is AP3964272
P.S. The above link does not work any more. The tech sheet is attached to the post.
File Attachment(s):
Tech Sheet - 8206560 _ MH2175XSQ0.pdf (593kb) downloaded 61 time(s).
edwards
#3 Posted : Saturday, March 29, 2008 7:56:59 PM(UTC)
edwards
Whirlpool MH1150XMT-0 Fan will not run when oven is on unless you manually press fan and then only on high. No low speed. Bad door switch ? fan hi low switch or relay?
#4 Posted : Tuesday, April 1, 2008 8:23:05 PM(UTC)
Hi Edwards,
Most likely the problem is a bad control board.
- The part number for the control board is AP3885533
Here are the break down diagrams for the Whirlpool microwave Model MH1150XMT0
mofire237
#5 Posted : Sunday, April 29, 2012 6:16:57 AM(UTC)
mofire237
The fan on our Whirlpool Microwave MH2175xsq0 stopped running today. When I try to manually run it the word SOUP appears on the display. The rest of the functions on the control panel work fine. Down to the fan?
#6 Posted : Sunday, April 29, 2012 3:08:19 PM(UTC)
Sounds like the problem is a bad control board, but you may want to perform the troubleshooting as described in the attached tech sheet (page 7 & 9).
- The control board Part number: 8206619
Here are the breakdown diagrams and Replacement parts for Whirlpool MH2175XSQ0 Microwave Oven 1.7 Cu. Ft. | AppliancePartsPros.com
File Attachment(s):
Tech Sheet - 8206560 _ MH2175XSQ0.pdf (593kb) downloaded 18 time(s).
Whirlpool microwave vent fan not working (Microwave Repair)
by mshaw8099 7/22/2015 2:07:41 PM(UTC)
