fred bruning
#1 Posted : Wednesday, April 25, 2012 10:42:17 AM(UTC)
fred bruning
Matag SDG3606AWW Dryer I have just replaced the (1) motor (2) belt (3) drum support rollers (4) drum glides and felt (5) idler arm and pulley assembly and (6) spring. The dryer will now start and the motor will turn the drum but when I put in a normal load the drum will not turn. any suggestions.
Simon / APP Team
#2 Posted : Wednesday, April 25, 2012 1:06:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if the belt installed correctly and if the drum turns freely.
. Simon.
fred bruning
#3 Posted : Wednesday, April 25, 2012 4:08:38 PM(UTC)
fred bruning
yes, the belt is installed per the forums advise and yes the drum turns, it will turn with just several garments but will not turn with a normal load
Simon / APP Team
#4 Posted : Thursday, April 26, 2012 9:28:09 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is no miracles. Please double check everything you installed. If all checks OK - then, possibly you have bad motor.
The motor Part number: 2200376
Thank you.
Simon.
fred bruning
#5 Posted : Thursday, April 26, 2012 1:01:58 PM(UTC)
fred bruning
FYI, the belt diagram in the forums post for this model #SDG3606AWW is wrong. Matag's adivce for this model is that the ribs of the belt go against the drum "NOT Away" as the forums' diagram shows. http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html Please change the information as I'm sure it has caused others problems similar to mine.When I reversed the belt with the ribs facing the drum the the drum turns with a full load and the dryer works great. thanks for your response
Simon / APP Team
#6 Posted : Thursday, April 26, 2012 1:41:03 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Fred.
Sorry for the troubles and thank you very much for the correction. We' ll take care of it ASAP.
Thank you again.
Simon.
