craiglevitan
#1 Posted : Tuesday, April 17, 2012 6:45:10 AM(UTC)
craiglevitan
Upon testing the control, I found that the control is only putting out 18 volts via a 2 pin connector to the D.L.B. Relay coil. The coil is rated 24 volts and is not closing the N.O. contacts. I replaced the control and the output is still 18 volts instead of 24 volts. Has anyone got any advice?
ApplianceJunk
#2 Posted : Tuesday, April 17, 2012 8:21:26 AM(UTC)
ApplianceJunk
Hi,
Check for bad connections.
Would you like a copy of the service manual or do you have it already?
craiglevitan
#3 Posted : Tuesday, April 17, 2012 8:38:46 PM(UTC)
craiglevitan
I would love a service manual. Craig
ApplianceJunk
#4 Posted : Tuesday, April 17, 2012 8:42:41 PM(UTC)
ApplianceJunk
Here you go.
http://bit.ly/IWRKuV
craiglevitan
#5 Posted : Wednesday, April 18, 2012 6:46:21 AM(UTC)
craiglevitan
Got It. Thanks a bunch! Craig
