Whirlpool Microwave Hood Combination-- How does one get to and then remove the 3-button switch assembly (AP3132120)– (Vent Fan – Light – Turntable)? The buttons are at the bottom below the control panel. I assume you remove the bottom of the microwave first. Then,how does the control panel come off? [FONT="Times New Roman","serif"]Thanks [/FONT]
Groups: APP Team
Hi.
Remove the top grill first and you will see the screw on the top of the control panel. Remove it too. Then lift the panel up and out.
Thank you.
Simon.
Simon --
Thank you for the reply. It sounds straightforward so I'll order the replacement switch assembly today.
Best wishes,
Mike
