2 Pages<12
dumamud
#11 Posted : Friday, January 13, 2012 7:32:58 PM(UTC)
dumamud
My washer would quit just before the spin cycle - with about 7 minutes left in the cycle, and just beep about 3 times as it turned off.
This was exactly what I needed. I bought the switch myself and not only got it cheaper than the repair man quoted, but I saved the $70 diagnostic fee plus labor. All together saved about $155. Oh yeah! Thanks!:D
I used the youtube link earlier in this thread, which was very helpful.
Harvester
#12 Posted : Monday, April 16, 2012 3:16:13 PM(UTC)
Harvester
I just had the same problem with my Frigidaire washer LTF2049EEO. I see many people with the same problem and I kept seeing that it could be the door latch assembly. It didn't make sense to me, because the washer would fill with water, would wash, rinse and drain. The only thing it would not do is spin.....I checked the drain hose and nothing was stuck in it. I took off all the hoses and found no blockages. The coin catcher was clean. I removed the pump but was unable to open it. I took the chance and ordered the door latch assembly. When it arrived, I watched a video that was posted on another site that showed exactly how to remove and replace the part. It literally took one minute to remove the old door latch assembly and another minute to install the new one. And YES, it did fix the problem!!! My washer is running just fine and spins just like it is supposed to. (one hint for anyone trying to remove and check their hoses...It is very difficult to open up the spring clamps and keep them open while trying to slip the hose off if you use regular pliers.. Use vice grips so that they won't keep slipping off the tabs on the spring clamps. This will save lots of time when trying to remove the hoses)
2 Pages<12
