Dryer won't start. Have checked the circuit breaker and door switch- both okay.
Groups: APP Team
Hi. Sounds like the problem is burned thermal fuse. Remove the rear panel, locate the the fuse mounted on the blower housing. Take one wire off the thermostat and using the multimeter check if the fuse is good. If it's open - replace the fuse. Make sure, that all the vents internal and external are clean, before using the dryer. The thermal fuse Part number: 3392519
Thank you. Post the results. Simon.
