My husband and I own a gas Kenmore oven/stove combo, model number 362.75206891. The stove works fine, but when I went to use the oven tonight it will not turn on. We have tired to see if we can find an obvious problem, but we cannot. We have tried turning a burner and the oven on at the same time to see if that will help, but nothing, the oven will not come on. Any ideas?
Most likely the problem is a bad Bake igniter (#218 on the diagram). You have to remove the oven floor and the flame spreader to access the part. - The part number for the igniter is AP2634719Gene.
