bbemis
#1 Posted : Tuesday, November 27, 2007 8:48:37 PM(UTC)
bbemis
Problem: Will drain, won't spin Question: Repairman told me for $350+ - he would fix washer and replace broken control board and motor.
I replaced both the speed control board and the motor. First, I replaced the speed board and was able to run about 4 loads. Then the machine would get to the final or fast spin cycle but would never kick into the spin. So I went ahead and replaced the motor but no change.
The tech sheet was missing from my washer. I have a multimeter to test but honestly have no idea how to use it.
All of the service manuals that I have seen or been provided appear to be from 2002 or 2003 but i think my washer was manufactured in 1998 if that makes a difference.
Since I have invested so much already I am hoping that I can still fix it without having someone look at it. But at a loss as to where to go from here.
Any help is most appreciated.
Thanks.
:confused:
okbobcats
#2 Posted : Wednesday, November 28, 2007 3:48:35 AM(UTC)
okbobcats
check your wire connectors to make sure they are tight. are you saying it work 4 times then stop workin again?
bbemis
#3 Posted : Wednesday, November 28, 2007 6:46:59 AM(UTC)
bbemis
Wire Connectors - on the speed control board that was replaced, correct?
Yes, it ran for approx 4 loads before it stopped spinning. It runs through all other cycles fine.
Thanks in advance. :)
Frigidaire front load washer won't spin dry (Washer Repair)
by SteveMD 10/23/2011 4:46:45 PM(UTC)
Frigidaire front load washer won't spin (Washer Repair)
by jociadam 7/2/2008 10:13:00 AM(UTC)
