Just replaced both water inlet valves yet water dispenser still drips somewhat. Any suggestions? thanks
Disconnect the water line coming out from the new water valve to make sure the problem is not with the new valve. Try the dispenser to see if the water stops there where you have it disconnected. There is a strainer before the valve that may need cleaning and some sediment could have stopped up the new valve.
Just to add my 2 cents... Drain 1 or 2 gallons of water though the water dispenser to get rid of air in the system.
