necibill
#1 Posted : Monday, March 16, 2009 6:42:08 PM(UTC)
necibill
Machine fills with water but won't agitate, spin or then drain. Screen code indicates overloaded, but does the same thing even when empty. Advice?
Whirlpool Calypso
#2 Posted : Tuesday, March 17, 2009 4:01:55 AM(UTC)
Replacement parts for WHIRLPOOL GVW9959KT1 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208530143.pdf
And here is a service manual
https://secured.whirlpoo...8aaaae885256c5d004632a4/$FILE/8178010.pdf
Hopefully the above info will help.
I could not find an overloaded error code!!!
necibill
#3 Posted : Tuesday, March 17, 2009 3:14:54 PM(UTC)
necibill
The code was Ld, which I thought was overload, but it is "long drain." I did the spin and drain test per the instructions and it did nothing but make a humming noise (like it does anytime I turn it on now.) It does have water in it.
Of course I can't do the "drain and recirculation test" so is there any way to know if it's the pump, the pump motor or the wiring harness?
Thanks,
Bill
#4 Posted : Wednesday, March 18, 2009 5:35:56 AM(UTC)
See page 15 in the tech sheet, Test #7
