neptune167
#1 Posted : 13 years ago
neptune167
I pushed the start button, the timer was moving but the motor didn't start. I have replaced the thermal fuse, drive motor, cycling thermostat, thermal cut-off kit and door switch. However, that still didn't solve the problem.
#2 Posted : 13 years ago
Replacement parts for Whirlpool LEC6848AN1 ELECTRIC DRYER | AppliancePartsPros.com
The cycling thermostat and thermal cut-off have no effect on the motor starting.
Here is the start circuit for timed dry.
NEUTRAL , DOOR SWITCH D1/D2 , TIMER SWITCH 4 T/W , motor's centrifugal switch , START and MAIN motor windings , THERMAL FUSE , PUSH TO START RELAY R2/R1 , timer contacts BU/BK , L1 120 volts.
Since you have replaced a lot of the parts all that is left is the timer contacts and the start relay or you have a bad connection in the circuit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LEC6848.pdf (95kb) downloaded 13 time(s).
Maytag Neptune Dryer Doesn't Start on /off (Dryer Repair)
by torrealtl1 11 years ago
Whirlpool Dryer doesn't start (Dryer Repair)
by PrinceEnder 12 years ago
GE Dryer Doesn't Start (Dryer Repair)
by gmoney6 13 years ago
Dryer doesn't start. (Dryer Repair)
by sanmigmike 14 years ago
Whirlpool Electric Dryer doesn't start until timer reaches cool down cycle (Dryer Repair)
by noclaf1 16 years ago
by footsie 17 years ago
by doug7as 17 years ago
