gijanedup
#1 Posted : Sunday, April 1, 2012 6:45:50 PM(UTC)
gijanedup
My dryer quit heating. I have tried it on different settings, but to no avail. The fan is working,however, there is no heat emitted. I would think this would be the heating element, but I am not sure. I can't afford to call the repairman. It's quite costly. Do you have any suggestions? If it is the heating element, how do I get to it and replace it?
#2 Posted : Tuesday, April 3, 2012 3:03:22 AM(UTC)
Replacement parts for Whirlpool LER8620PW0 29"ELECTRIC DRYER | AppliancePartsPros.com
Unplug the unit and remove the rear panel and both wires to the heating coil and check it with a meter. Should be around 10 ohms. Also check from each heater connector to the frame, both should be infinite ohms.
If the heater is good check the thermal cut-off. It should be 0 ohms.
If it is open (infinite ohms) then the heater may have blown it that is why you check the heater to the frame (ground) just to be sure that it is not grounded.
But before doing the above I would do the following as the heater requires the full 240 volts but the motor runs on half the line (120 volts)
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 7/28/2016 11:44:39 PM(UTC)
Maytag gas dryer is not heating (Dryer Repair)
by adrianne 8/11/2010 10:31:59 AM(UTC)
Dryer is not heating keep getting a code "he" (Dryer Repair)
by Njones-frye 6/22/2010 2:20:25 PM(UTC)
Gas Dryer is not heating (Dryer Repair)
by pamela2010 2/25/2010 3:58:00 AM(UTC)
by leaford 6/21/2008 2:55:36 PM(UTC)
