Boogers
#1 Posted : Saturday, March 31, 2012 6:32:13 PM(UTC)
Boogers
Hello,
I found this forum through Googling my problem, and I've been reading the stickies. While I'm reading this I thought I'll post my problem.
Our 2 year old Kenmore fridge is not working but the freezer is perfectly fine. With some helpful posts around here I removed the back panel in the freezer. Here are some pictures of it:
http://www.flickr.com/photos/69.../sizes/l/in/photostream/
So far I checked that the fan is working flawlessly and no problems with it. It took about 20 minutes to open the back panel and while I was prying it apart, obviously the freezer cooled down. Then I took pictures and noted some stuff down then closed it back up. I checked the fridge after and a little bit of cool air started to air in.
I'm also wondering where I can find a diagram of my model.
Anyone know what to do next?
Thank you for your help.
richappy
#2 Posted : Sunday, April 1, 2012 2:01:13 AM(UTC)
richappy
Open the fridg door and press the light switch 5 times within 6 seconds, compressor should stop, and it should go into defrost.
If compressor stops, but no defrost action, you have either a defrost thermostat, or defrost heater problem.If compressor will not stop, you probably have a bad control board.
Boogers
#3 Posted : Sunday, April 1, 2012 4:38:41 AM(UTC)
Boogers
How do I tell if the compressor stopped? I pressed it multiple times and it didn't seem like it did anything. Then I rapidly pressed it about 5 times, and it made a rumbling sound for about 4 seconds and it stopped.
Can you also tell me where I can find the diagram so I know what is what? When I put in the model number it just give me the parts list, I don't see a diagram.
Thanks.
richappy
#4 Posted : Sunday, April 1, 2012 5:53:44 AM(UTC)
richappy
Try the sears site" searspartsselect", will give diagrams. If the fans stopped after pushing the door switch, it went into defrost, but probably didn't defrost due to a defrost component failure like a defrost thermostat.
richappy
#5 Posted : Sunday, April 1, 2012 5:55:50 AM(UTC)
richappy
Try the sears site" ********************************", will give diagrams. If the fans stopped after pushing the door switch, it went into defrost, but probably didn't defrost due to a defrost component failure like a defrost thermostat.
Boogers
#6 Posted : Sunday, April 1, 2012 7:43:49 AM(UTC)
Boogers
You mean by defrost action, the frost on the evaporator has to melt?
Great, found the schematics! So if I press the switch about 5 times, the fan blade (6) from this diagram, should stop spinning?
http://www.********************...=&shdMod=59665333700
This is how it looks like this morning. I'm not sure when it defrosted, after I opened it last night or after this morning where I did the light switch.
jcellini
#7 Posted : Monday, April 23, 2012 5:15:18 PM(UTC)
jcellini
I have the same problem. Did you ever get your problem fixed?
Guest (6)
