Hello all,
I have a Whirlpool electric range/oven that has seen very little use over the past 3 years that I have owned it. A couple of months ago the oven started beeping and would not stop, until i threw the breaker. The message on the keypad says F2. The stove top will work but the keypad, and therefore the oven, will not respond to any inputs. I would appreciate any info. and direction you guys could give me.
Thanks alot,
Andy
I could not find any info on this model number. Tried AppliancePartsPros and 2 Whirlpool sites. Please check it. I can tell you that on many Whirlpools F2 is an oven sensor fault. So it may be the problem. Here is a good site with info on how to check it, see 7, 8, 20 and 21. http://www.applianceaid.com/elecrange.html |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman I could not find any info on this model number. Tried AppliancePartsPros and 2 Whirlpool sites. Please check it. I can tell you that on many Whirlpools F2 is an oven sensor fault. So it may be the problem. Here is a good site with info on how to check it, see 7, 8, 20 and 21. http://www.applianceaid.com/elecrange.html Denman, Im sorry about the model number, I mistook the W for an X. The actual model number is: WFE361LVD 0 I hope that the corrected serial number helps and I look forward to some guidance. Thanks again, Andy
