Miguel*Paredes
#1 Posted : Tuesday, March 27, 2012 8:52:48 PM(UTC)
Miguel*Paredes
Hello,
I've been trying to repair Side-by-Side 26 cu. ft. Frigidaire refrigeratormodel number FRS266ZDSB4 and yesterday I installed a 3 in 1 Start (SupcoRCO210 for 1/2 HP compressor) and this is what I did:
I placed the ammeter on the white wire (Start compressor terminal) and thenI plugged the unit in, the amperage on the white wire read 8.10A and thecompressor worked for about 2 seconds and shut off leaving only at .10 A withthe fan on. After a few minutes I tried again the same procedure and this timethe compressor did not run at all and the ammeter showed .12 A and only the fancame on. What could be happening? I checked the compressor terminals and thewindings appear to be in good shape: Common 9.6ohm, Start 5.9ohm, and Run 4.1ohm so Ibelieve the compressor could not be the problem, but I think that there might be an electricissue that is hindering the compressor from working normally? Please advise.
Thank you very much in advance for your reply!
Miguel
richappy
#2 Posted : Thursday, March 29, 2012 2:44:23 AM(UTC)
richappy
You should NEVER use a 3 n 1 hard start device, they will eventually blow out the compressor. Also, I have never seen a modern R134A compressor with a 1/2 hp rating, so you installed the wrong start device.
If your windings are now open, you blew them out. If they show resistance, like 3 to 5 ohms, unfortunately, the only way you can verify the compressor is good is to install the proper start device, AP3837323
New motherboard, now compressor not working (Refrigerator & Freezer Repair)
by Jeanebk 6/19/2020 4:36:51 PM(UTC)
compressor not working. clicking relay (Refrigerator & Freezer Repair)
by felix2351 12/23/2012 4:33:04 AM(UTC)
GE compressor not working (Refrigerator & Freezer Repair)
by kurtd 11/23/2012 10:23:31 AM(UTC)
refrigerator / freezer compressor not working (Refrigerator & Freezer Repair)
by Joseph Folgado 4/25/2012 11:28:40 AM(UTC)
Compressor not working (Refrigerator & Freezer Repair)
by Miguel*Paredes 3/27/2012 8:53:30 PM(UTC)
by audley 10/1/2011 7:23:32 AM(UTC)
GE Profile COmpressor not working (Refrigerator & Freezer Repair)
by 15fer 8/24/2011 2:38:15 PM(UTC)
by falcon80 7/16/2011 10:04:05 AM(UTC)
by btournas 11/23/2010 12:28:31 PM(UTC)
by turboyam 10/23/2010 6:58:02 AM(UTC)
Kenmore Elite side by side compressor not working? (Refrigerator & Freezer Repair)
by stupidfridge 9/22/2010 12:49:10 PM(UTC)
Compressor Not Working (Refrigerator & Freezer Repair)
by tommyboy4242002 8/8/2010 5:12:21 PM(UTC)
Buzzing noise, compressor not working (Refrigerator & Freezer Repair)
by steve R 1/4/2010 9:37:59 AM(UTC)
Compressor not working, even after replacing relay/capacitor (Refrigerator & Freezer Repair)
by Amine 5/22/2009 5:00:34 PM(UTC)
by zjiqi0 12/21/2007 4:42:54 AM(UTC)
