2 Pages12>
ionized
#1 Posted : Friday, March 23, 2012 9:26:51 PM(UTC)
ionized
I don't know where to look for a model number. I see several on the manual: 15791, 15795, 15798, 16791, 16795, 16798.
It seems to run a whole cycle, but is full of water at the end.
ionized
#2 Posted : Saturday, March 24, 2012 5:40:56 AM(UTC)
ionized
I found the tag. It looks like a model number 665.15798.790.
Where should I start?
ionized
#3 Posted : Monday, March 26, 2012 10:36:35 AM(UTC)
ionized
I put some food coloring into the water in the first wash cycle to see if it drains between wash and rinse. It stayed blue at the end.
#4 Posted : Monday, March 26, 2012 2:00:58 PM(UTC)
Remove the bottom panel. Disconnect the drain hose from the check valve (#15 on the attached picture). Be prepared to catch the water remaining inside the dishwasher. Unscrew the check valve and make sure it is clean inside.
In case if you would not be able to clean it or if some parts of it are missing, replace the check valve.
- The check valve Part number: AP2910020
Gene attached the following image(s):
ionized
#5 Posted : Tuesday, March 27, 2012 10:06:38 AM(UTC)
ionized
Thanks, I will look into the check valve. It will likely be the weekend before I have time.
#6 Posted : Tuesday, March 27, 2012 2:16:10 PM(UTC)
ionized
#7 Posted : Tuesday, March 27, 2012 8:08:01 PM(UTC)
ionized
I took out the check valve and it seems to be clear as does the drain. Water seemed to run freely from the tub. I suppose, however, there could be a clog above the check valve connection that allowed water do seep through slowly and then pour out when the valve was removed. I can check that tomorrow. If that is not it, what is next, check the pump? If so, how do I do that? I might be able to cobble together some scrap tubing that I can adapt to the check valve and drain hose.
#8 Posted : Wednesday, March 28, 2012 3:01:03 PM(UTC)
Do you have an air gap on top of the sink?
ionized
#9 Posted : Wednesday, March 28, 2012 3:06:57 PM(UTC)
ionized
No air gap. I have been holding back. This DW is hooked up in an unconventional and, perhaps, not code compliant way. I knew for a long time that it is not hooked to the plumbing on the double sink next to it. It is a raised house with an open crawl space. There is insulation between the joists so I never fully investigated. I can now see under the DW and it has its own trap next to the back wall.
#10 Posted : Thursday, March 29, 2012 1:39:55 PM(UTC)
If you can, disconnect the other end of the drain hose. Make a loop about 24" high and put the hose end in a large bucket. Run the dishwasher to see how it will drain. It will help you to determine if the problem is within the dishwasher or outside.
2 Pages12>
