Darrell Jenkins
#1 Posted : Tuesday, March 27, 2012 12:39:10 PM(UTC)
Darrell Jenkins
The washer does not agitate. When wash cycle is started, it fills, sits without agitating, spins out, refills and spins again. Everything normal except no agitate. Motor is not running when it should be agitating.
Both door switches make and break when door is opened and closed. (Checked with power off --continuity. power on -voltage)
Water level switch is working. I do know how to troulbleshoot electrical systems on aircraft but this washer is magic to me:o Please help.
#2 Posted : Tuesday, March 27, 2012 3:27:03 PM(UTC)
Hi Darrell,
Here is the wiring diagram for this washer. Check for the proper voltage to the motor.
If the voltage is correct, replace the motor.
If the voltage is incorrect, replace the timer.
- The motor Part number: AP4009168
Washer does not agitate (Washer Repair)
by ccastr1 8/1/2013 7:21:27 PM(UTC)
Washer does not agitate on regular cycle (Washer Repair)
by Volpone 7/13/2013 12:49:46 PM(UTC)
Washer does not agitate or spin (Washer Repair)
by rags1 5/3/2013 12:42:16 PM(UTC)
Washer does not agitate properly (Washer Repair)
by DickMig 2/24/2013 5:34:47 AM(UTC)
Whirlpool washer does not agitate or spin (Washer Repair)
by rkgeorges 12/9/2012 9:47:35 PM(UTC)
Washer does not agitate or spin but drains (Washer Repair)
by howardscott 10/8/2012 2:08:32 PM(UTC)
by jvd819 12/11/2011 10:38:39 AM(UTC)
by sheliahiro 10/27/2011 6:08:13 AM(UTC)
Washer does not agitate in Gentle cycle (Washer Repair)
by malgase 5/7/2011 3:05:43 PM(UTC)
ge washer does not agitate or spin (Washer Repair)
by brunac10 1/5/2011 6:12:03 AM(UTC)
by nomadx 10/20/2010 6:49:24 PM(UTC)
by Tbecker 9/6/2010 2:04:03 PM(UTC)
by acekun 8/7/2010 7:26:42 PM(UTC)
Washer does not agitate, spin or drain (Washer Repair)
by nun4joy 4/21/2010 2:27:28 PM(UTC)
GE Washer does not agitate or spin (Washer Repair)
by Tammy2006 2/7/2010 7:40:57 PM(UTC)
