dneus
#1 Posted : Monday, March 26, 2012 8:50:44 AM(UTC)
dneus
Purchased 09/2010- Heater Element Replaced ( Fried). Upon Replacement - The Clean Light blinks 7 times then pauses then 7times again & Again.When Selecting Control Panel Options - all the selection light BUT when you select the start Button _ Comes On Then Goes Off- NO Operation of diswaher. The Only operable selection is the Cancel/Drain -Two minutes then goes off.
Problem Due To ??
ControlPanel R Main Control Board
#2 Posted : Monday, March 26, 2012 11:42:59 AM(UTC)
Check the high limit thermostat (#25 at the diagram) for continuity. Replace if it's open.
- The high limit thermostat Part number: AP3010530
dneus
#3 Posted : Monday, March 26, 2012 12:11:22 PM(UTC)
dneus
Will Give It A Shot
Many Thanks -
dneus
#4 Posted : Monday, March 26, 2012 12:20:07 PM(UTC)
dneus
Originally Posted by: dneus Go to Quoted Post
Will Give It A Shot
Many Thanks -
I should have asked this question upfront- What would be the cause of the heating element to short out. Just Wondering
#5 Posted : Monday, March 26, 2012 12:23:04 PM(UTC)
Good question!
It can be anything from poor quality to excessive current.
dneus
#6 Posted : Tuesday, March 27, 2012 5:38:04 AM(UTC)
dneus
Will Give It A Shot
Many Thanks -
Had Ckd @ Is Closed - Which I think -means that is not the problem.
- A Faulty Keypad @ r Main Control Board .?
#7 Posted : Tuesday, March 27, 2012 1:29:02 PM(UTC)
Yes, the high limit thermostat passed the test, so the control board is the next. Make sure all wires are good.
- The control board Part number: AP4566308
Guest (5)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
