juliem922
#1 Posted : Friday, March 23, 2012 9:43:20 AM(UTC)
juliem922
I had a new floor put in which required the dishwasher to be moved in order to install the new floor under it. When the dishwasher was moved the water was turned off to the machine, but no other disconnects were made. Now the dishwasher will not fill with water. Any ideas? The water has been turned back on to the machine, but when I start it...no water is filled into the machine. It seems like it needs to be reset...but I'm not sure how to do that.
#2 Posted : Friday, March 23, 2012 8:11:20 PM(UTC)
So, if I got it right, you did not disconnect the water line from the dishwasher? You just turned off the water shut off valve under the sink?
If this is correct, make sure the water is coming to the dishwasher. Something can be wrong with the water shut off valve.
