Hello, I Have A Possessed Stove. I Have A 2nd Hand Stove And When The Electric/gas Were Connected, The Oven Energized The Ignighter, The Gas Valve Opened And The Over Burner Ignited And Began To Run Although The Knob Was In The "off" Position. I Was Able To Turn It Off By Turning The Knob On/off, Listening To The "clicks" Of The Microswitch In The Knob Assembly. The Oven Will Energize Quit Regularly And Will Heat For A Bit And Then Turn Itself Off WHILE THE OVEN KNOW IS IN THE "OFF" POSITION. It Is Obviously A Problem. I'm Looking For Suggestions. I Don't Know If It Is The Thermastate Assebly Or The Gas Valve Or Something Else. I Thank U For Ur Support.
Most likely the problem is a bad thermostat and to fix it the thermostat has to be replaced. - The part number for the oven thermostat AP2623073 - Here are the break down diagrams for the GE range Model JGBS23BEA2WHGene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Most likely the problem is a bad thermostat and to fix it the thermostat has to be replaced. - The part number for the oven thermostat AP2623073 - Here are the break down diagrams for the GE range Model JGBS23BEA2WHGene. THANK U SIR, I KINDA THOUGHT THAT AND B4 I MADE THE INVESTMENT INTO "PROBABLY" THE POSSESSED PART I JUST WANTED 2 C WAT ANY1 ELSE MIGHT HAVE THOUGHT. IM GONNA GIVE IT A TRY AND I WILL LET U KNOW HOW IT TURNED OUT IN A COUPLE OF DAYS!!!
Thanks For Ur Advice, I Replaced The Thermastat And The Was The Problemo!!!!! Thanks Thanks!!!!!
