Michellej10
#1 Posted : Monday, March 19, 2012 4:20:26 PM(UTC)
Michellej10
Is there an absolute way you can tell if it is the clock assembly or control panel that is giving this message...can't afford a repairman!!!!:cool:
Jerry / APP Team
#2 Posted : Thursday, March 22, 2012 8:22:08 AM(UTC)
mattt
Groups: Guests
Hello Michelle,
Try this. Discontinue power to the unit to prevent electrical shock. Remove the control panel and disconnect the ribbon cable to the panel. Re-establish power to unit. If the fault reoccurs, you will hear the beeping only since the panel isn't hooked up to display the code, and this indicates that the clock assembly needs replaced. If the beeping doesn't sound, the panel needs replacement.
