williape
#1 Posted : Thursday, March 12, 2009 2:14:13 PM(UTC)
williape
My whirlpool microwave has developed a discoloration between the outer door glass and the door frame. Item 2 and 7 on the parts drawing. I have beed able to remove inner door panes(choke cover) but I cannot figure out how to remove the door frame unit AP3892363 so that I can replace it. It is stuck in the door panel pretty good. Can anyone help.
TechnicianBrian
#2 Posted : Friday, March 13, 2009 5:40:32 AM(UTC)
TechnicianBrian
The outer panel is attached to the metal choke by many plastic tabs much like the choke cover. I usually start at the middle top with my putty knife and press each tab as I work my way around the door. It takes some doing and you may even break a tab or two, but it won't be a safety issue when it goes back together.
williape
#3 Posted : Friday, March 13, 2009 6:56:26 AM(UTC)
williape
I will give it a try. thanks for the information
TechnicianBrian
#4 Posted : Friday, March 13, 2009 7:04:12 PM(UTC)
TechnicianBrian
Glad I could help. Let us know how you make out.
Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by Amsel7 11/29/2013 7:26:50 AM(UTC)
Outer Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ksouthar 11/15/2012 6:40:58 PM(UTC)
Kitchenaid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by drill 1/6/2012 5:48:30 AM(UTC)
KitchenAid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by gglbox 3/8/2010 6:18:55 PM(UTC)
oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by Eggman 10/14/2009 1:37:50 PM(UTC)
Microwave Door Glass Replacement (Microwave Repair)
by Johne. 7/12/2009 7:16:42 PM(UTC)
by nelsonflint 12/19/2008 10:18:16 AM(UTC)
Oven Door Glass Replacement - Help! (Oven Repair (including Ranges and Cooktops))
by VWC318 11/21/2008 2:04:56 PM(UTC)
Oven Door Glass Replacement Question (Oven Repair (including Ranges and Cooktops))
by ckrobins 2/21/2008 3:19:21 PM(UTC)
Oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by rondelaney 1/20/2008 5:50:19 AM(UTC)
Gas Range Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ronkat 11/16/2007 3:08:54 PM(UTC)
