glenn1
#1 Posted : Monday, November 26, 2007 1:23:49 PM(UTC)
glenn1
The Whirlpool Gas Dryer CG2951XSN2, ICX3414556 does not dry the heavy materials like jeans completly. How do I check for the temperature of the dryer reaches 125 degrees or more ? The venting leading outside is OK. I changed thermal fuse #2986 and Gas valve solenoid coil kit #3479. Do you think I have a bad drum felt seal ? I do not see this model number on the web site.
#2 Posted : Monday, November 26, 2007 2:43:10 PM(UTC)
The first thing I would check is condition of the blower wheel (#10 on the bulkhead break down diagram) and the chute (#1 on the same break down diagram) on the back of the dryer.
It should be "W" instead of "N" in the model number.
- Here are the break down diagrams for the Whirlpool dryer Model CG2951XSW2
