Jeff G.
#1 Posted : Tuesday, March 20, 2012 5:58:24 AM(UTC)
Jeff G.
My Ice maker is receiving water and making cubes. The dispencer on the outside freezer door is not working. The lights are on but no water or ice comes out when the push lever is engaged. Any suggestions?
#2 Posted : Tuesday, March 20, 2012 12:51:16 PM(UTC)
Does it make any noise when you push the lever?
Would the dispenser lights dim when you push the lever?
If you answer No on both questions, open the dispenser (the instructions are attached) and check the parts inside. Especially the micro switch (#72 at the diagram).
Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric HSS25GFPJWW Refrigerator | AppliancePartsPros.com
File Attachment(s):
How to open ice dispenser.doc (97kb) downloaded 11 time(s).
Jeff G.
#3 Posted : Thursday, March 22, 2012 3:29:22 PM(UTC)
Jeff G.
Post the results.
The light does dim when lever is pressed. Also I notice the motor thats running in the back stops when the lever is pushed. I tried a new switch #72 and I tried a new front panel #93. Niether one did any difference. What is my next option? I will return these two items.
#4 Posted : Friday, March 23, 2012 1:52:34 PM(UTC)
Originally Posted by: Jeff G. Go to Quoted Post
...The light does dim when lever is pressed. Also I notice the motor thats running in the back stops when the lever is pushed...
These symptoms point to a bad main control board on the back of the refrigerator.
- The main control board Part number: AP4436216
