Sink backed up. Cleared sink drain line. Restarted dishwasher; no water. Cleared d/w input water filter (some black slimy-silt). A little water still left in the drain area. Sounds as if pump is running but still no water.:confused:
try pouring a gallon or so water in your dishwasher. then start it. your level switch may off got hung up with some crude. This may clean your drain line where the level switch is. I
Tried to do that and the wash cycle works but never pumps the water out of the machine.
