Hello,
I have a Frigidaire model PLMB209DCC microwave. The fan runs and the turntable turns whenever the door is opened. The magnetron does not appear to activate.
I have read elsewhere on this forum that this is usually caused by a door switch.
The diagram for this model lists 2 door switches. Which one would cause this behavior? Should this switch test closed or open when depressed?
Thanks! (Edited - Subject should say "Fan and Turntable Activate on Opening", not "Light".)
