GPete76
#1 Posted : Tuesday, February 28, 2012 2:06:14 PM(UTC)
GPete76
Forum Rank:: Member
My Amana has been having intermittant problems. A couple weeks ago the coils froze up, I tested the defrost timer, heater and thermostat and all checked out ok. After reading so forum posts, I ordered a new defrost timer. While waiting for the part, I took the fridge out on my deck and blew all the accumulated dust from under the unit with an air compressor. After hooking it back up it worked fine for 6 days, then we came home and it was completely defrosted. I unplugged it and installed the new defrost timer, after plugging it back in, the fan started but the compressor did not. The compressor was hot to the touch. I unplugged it again and left it that way for 2 days. Yesterday I called a neighbor who has been in the refrigeration business for 40+ years, he came over and said the compressor checked out ok. When I came home from work last night, I plugged it back in and heard the compressor start up. A couple hrs later it still hadn't cooled down and I heard it trying to cycle on and it clicked back off quickly several times. When I checked it this morning it still hadn't gotten cold. Stopped back home during work about 3 hrs later and it had made ice in the ice maker. 6 hrs later when I get home from work it's still cold and running. What's happening with this? New compressor about 18 months ago.
richappy
#2 Posted : Friday, March 2, 2012 1:42:39 AM(UTC)
richappy
Seems like you have a hard starting compressor in this. It could also be shutting down on it's overload. Next time it fails, verify the condensing fan is running.
GPete76
#3 Posted : Thursday, March 8, 2012 5:10:00 PM(UTC)
GPete76
Forum Rank:: Member
Condensor fan is running, but compressor is not. It will run for 5-6 days great, then one day it is not cooling and the condensor fan is running. The compressor pulls 6.2 amps when I first started it and gradually climbs up to 6.7 amps
richappy
#4 Posted : Friday, March 9, 2012 12:21:02 AM(UTC)
richappy
As you found out, no test with a meter will determine status of a compressor, only functional test with 115 volts will test it. Your amprobe confirms a burnt compressor.
Refrigerator/Freezer Not Cooling (Refrigerator & Freezer Repair)
by sytipton 7/18/2017 12:39:26 PM(UTC)
Whirlpool Refrigerator/Freezer not cooling Intermittenly (Refrigerator & Freezer Repair)
by mshilko 9/14/2016 9:33:30 AM(UTC)
Whirlpool Refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by tomk000 8/8/2015 2:11:22 PM(UTC)
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 5/27/2015 10:24:46 AM(UTC)
Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by dansally 7/14/2014 4:07:03 PM(UTC)
GE refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by dave27 4/1/2013 3:54:30 PM(UTC)
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 11/17/2012 11:44:40 AM(UTC)
GE Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by Steph Paine 10/28/2012 12:36:56 PM(UTC)
Refrigerator/Freezer not cooling properly (Refrigerator & Freezer Repair)
by dollar13 7/12/2012 11:02:06 AM(UTC)
by Quietpower10 7/2/2012 7:52:39 PM(UTC)
by t38263 5/29/2012 7:29:13 PM(UTC)
by jerosier 5/7/2012 12:09:11 PM(UTC)
Samsung refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by Deldolfan 12/24/2011 6:35:05 AM(UTC)
Refrigerator/Freezer Not cooling (Refrigerator & Freezer Repair)
by pendries 8/22/2011 1:54:22 PM(UTC)
admiral refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by sammay55 7/11/2011 7:18:51 PM(UTC)
