RICK GENZEN
#1 Posted : Tuesday, March 6, 2012 6:29:13 AM(UTC)
RICK GENZEN
Hi Our Whirlpool Front Loader Makes A Rattling And Growling Noise And Is Not Spinning.with Lower Cover Off It Sounds Like Something Rolling Around In The Front Drain Pump.i Put It On Another Cycle And It Spun A Couple Of Times And Started To Make The Noises As Before And Not Spin.the Machine Is 9 Years Old,what Part Should I Check To Solve This Problem. Thanks,rick
sidfink43
#2 Posted : Tuesday, March 6, 2012 5:24:32 PM(UTC)
sidfink43
You always start on this type of problem by taking of the pump and cleaning it out and cleaning out the drain hoses.
Whirlpool Duet Front Loader with LF error code (Washer Repair)
by tmylett 12/27/2014 3:18:29 PM(UTC)
Whirlpool Duet front loader help needed-no drain/pump comes on in wash cycle (Washer Repair)
by rdcleeann 10/1/2013 5:42:30 AM(UTC)
Whirlpool Duet front loader washer fills with water and stops F20 error (Washer Repair)
by DougN62 10/24/2012 3:55:35 AM(UTC)
tube not rotating on a whirlpool duet front loader (Washer Repair)
by dawn_cha2003 9/2/2011 11:20:58 PM(UTC)
