mrcclc
#1 Posted : Saturday, November 24, 2007 10:28:46 AM(UTC)
mrcclc
Just got this error code which apparently means that the oven is sensing temperatures of over 900 degrees - not good. My questions are: (1) what is the likely part that is needed to repair?; (2) what does it cost?, (3) can I do the replacement myself?; (4) what would a repairman likely charge? Thank you.
mrcclc
#2 Posted : Saturday, November 24, 2007 10:37:53 AM(UTC)
mrcclc
Don't know how to edit an already posted entry. My wife just told me that when the F2 message comes on the "Cook Time" light blinks. We've never used the Cook Time feature so we've never seen it blink except for now.
jumptrout51
#3 Posted : Sunday, November 25, 2007 5:34:56 AM(UTC)
jumptrout51
Probably a bad oven sensor about $50. Yes you can do it.
Unplug range from power. Remove oven racks. Locate sensor(a 3-6 inch by 1/4 inch metal probe).Usually at top of oven cavity,thru the back. Remove screws and pull out. Remove quick disconnect plug. Reverse order to install.
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
whirlpool duet sport dryer Error code F29 reappears (Dryer Repair)
by Herennow 4/14/2015 3:36:40 PM(UTC)
Error code F2 (Oven Repair (including Ranges and Cooktops))
by agrodon1 7/31/2014 11:01:50 AM(UTC)
Whirlpool error code f27 (Washer Repair)
by CRita 7/24/2013 5:37:50 PM(UTC)
GE oven error code F2 (Oven Repair (including Ranges and Cooktops))
by Tinadwalker 6/8/2013 4:26:29 PM(UTC)
Error Code F24 (Oven Repair (including Ranges and Cooktops))
by stampede 3/17/2013 2:57:15 PM(UTC)
KitchenAid Error code F2E1 (Oven Repair (including Ranges and Cooktops))
by meter12 2/2/2013 9:26:43 AM(UTC)
kenmore he3t, error code f28 (Washer Repair)
by bleonard 11/19/2012 11:15:17 AM(UTC)
error code F2:E3 (Oven Repair (including Ranges and Cooktops))
by brylev 6/19/2012 8:45:57 AM(UTC)
GE Error Code F2 (Oven Repair (including Ranges and Cooktops))
by jasonroach 5/20/2012 3:53:45 PM(UTC)
by wlemacks 10/7/2011 9:08:21 AM(UTC)
by wlemacks 10/7/2011 8:52:57 AM(UTC)
Error code f21 (Washer Repair)
by Waldo.S 9/15/2011 9:54:43 AM(UTC)
Error Code F21 Washer not draining (Washer Repair)
by Mr Bubba 9/6/2011 5:25:49 PM(UTC)
error code F22 (Washer Repair)
by sparks87144 8/20/2011 7:48:59 AM(UTC)
