nickbert
#1 Posted : Monday, February 27, 2012 11:30:06 AM(UTC)
nickbert
Dryer Won't Stay On. Only if you hold the start button in the dryer will run like normal ignites heats timer works bower works
Thanks in-advance.
Nick
#2 Posted : Monday, February 27, 2012 3:13:14 PM(UTC)
Hi Nick,
There are 2 identical relays and the control board inside the control panel.
The relay with the 2 blue wires connected to the large terminals is the motor relay while the relay with the 2 red wires connected to it is the heater relay.
To check the motor relay switch the motor and the heater relays by swapping the wires. Start the dryer as you always do.
If the motor will start normally, replace the motor relay.
If the same problem still exist, replace the control board.
- The motor relay Part number: AP3037419
- The control board Part number: AP4319168
nickbert
#3 Posted : Tuesday, February 28, 2012 9:48:45 AM(UTC)
nickbert
Thanks for the info I did cross the wires and still the same I thinks it's the control board as you said, are they know for going on this model?
Also I forgot to say that I cant get it into test mode.
Thank you Gene...
#4 Posted : Tuesday, February 28, 2012 2:59:27 PM(UTC)
The new control board should fix it.
