wyman
#1 Posted : Saturday, February 28, 2009 10:34:15 AM(UTC)
wyman
Well, my girlfriend's parents have all of their appliances from around the time they got married/had kids. They have a refrigerator from 1970 (and an older one in the basement!), but their newest appliance -- a GE Spacemaker Range and OTR Microwave from 1985 -- has seemingly just died (the microwave component, that is). I did a prelim search of the forums, and I'm guessing magnetron, but you'll probably know better than I.
The microwave:
- has power. I can "Time Cook" --> 1:00 --> "Start", and it will tick down to 0 and ding.
- makes no noise (other than the beeping from pushing buttons/ timer buzzing). That is, while the microwave is "running", there's no usual fan/whirring noise.
- does not heat. I just put a cold cup of ice water in there for a minute, and it was still ice cold at the end.
So, magnetron?
Are there any other tests I can do, with or without opening the microwave up? I am handy, but I have limited electrical experience. I do, however, understand both the dangers of the different internal components and the necessary precautions to take.
Thanks in advance.
wyman
#2 Posted : Thursday, March 5, 2009 11:05:26 AM(UTC)
wyman
Any advice would really be appreciated -- even if it's just "time to get a new range and microwave".
Thanks.
Drags1998
#3 Posted : Thursday, March 5, 2009 11:24:33 AM(UTC)
Drags1998
Before you trash it, open the control panel, discharge the capaciter, remove the control board, there is a 8or9 pin connecter on that board, If you look CAREFULLY at the back side of the board, pin#1 solder joint will most likely be bad, Repair that solder joint and use it for another 10 years(maybe!!!!!!!!!!}:D
rozman
#4 Posted : Sunday, March 8, 2009 9:36:18 AM(UTC)
rozman
hello! i have the same GE spacemaker appliance and my light bulb doesn't work. i was wondering if you know where it is and if you have a manual that tells you how to replace it? thank you.
rozman
#5 Posted : Sunday, March 8, 2009 9:41:26 AM(UTC)
rozman
hello! i have the same GE space maker and the light bulb is not working. i was wondering if you know how to replace it or have a manual thats shows how to replace it? Thank you.:confused:
Drags1998
#6 Posted : Sunday, March 8, 2009 12:16:23 PM(UTC)
Drags1998
If i'm not mistaken, you have to remove the unit from the wall.
rozman
#7 Posted : Monday, March 9, 2009 7:01:24 PM(UTC)
rozman
thank you ....i was afraid you were going to say that
umehta2005
#8 Posted : Sunday, August 1, 2010 2:13:26 PM(UTC)
umehta2005
Hi- I saw that someone else had this issue with their OTR Mircowave not heating.
My question is that I remove the Control Panel, but didn't see any burn out soder. Where should I look at.
The issue is that the Microwave is not heating but runs normally- no noise.
Is it worth buying new one or call a repair man.
It was manf in 1985
Thanks for any help.
