texican
#1 Posted : Thursday, March 5, 2009 5:43:41 AM(UTC)
texican
We have a Frigidaire (front load) washer from Nov.2006. The washer will move back and forth during the wash cycle, and it seems to drain, but when it goes to spin - nothing.
So we call out an appliance repair service and they quote us a repair cost of nearly what a new one will cost. (We say no thanks and pay the $65 call fee.)
The quote says that the main controller is bad (part number 134743500). Does this sound right? It looks like I can buy it for less than $150. Is it something that I can replace myself?
Or is something else possible wrong and this guy's quote is possibly inaccurate?
Thanks for any help!
TechnicianBrian
#2 Posted : Thursday, March 5, 2009 5:54:05 PM(UTC)
TechnicianBrian
It is possible the control is the problem, but I would do some more investigating before I jumped and made that purchase. There is a possibility that it may your door switch which I wrote about in a post Frigidaire Washer Won't Spin on my blog. Give it a read and see if that may be what your washer is doing. The tech sheet is in an envelope behind the access panel so you can do some of your own tests to help narrow down the problem.
texican
#3 Posted : Thursday, March 5, 2009 7:11:26 PM(UTC)
texican
I will look into it more, but I read through your blog and the first thing I noticed different was that ours does not move during the spin cycle at all (that one said it tumbled).
TechnicianBrian
#4 Posted : Thursday, March 5, 2009 7:26:22 PM(UTC)
TechnicianBrian
When it is time for the spin cycle, if your washer drains and just sits there, then the lock is not the problem, but then we are looking more at the control board. The tech sheet contains a set of tests that you can do to verify if it is the control or the motor controller that is causing the problem. Let us know if you need help with the tests.
Blackheart
#5 Posted : Monday, March 16, 2009 3:15:27 PM(UTC)
Blackheart
Where would one find the tech sheets?
David
TechnicianBrian
#6 Posted : Monday, March 16, 2009 3:38:13 PM(UTC)
TechnicianBrian
The tech sheets are generally behind the lower access panel on Frigidaire's.
Blackheart
#7 Posted : Monday, March 16, 2009 4:03:39 PM(UTC)
Blackheart
Thank you so much. Now I have to figure out how it comes off. The one on the dryer just pops off. I am sure I cannot be as lucky...grin
David
Guest (5)
Frigidaire Washer Won't Spin after replacing drive belt (Washer Repair)
by Shindigit 5/4/2013 10:54:15 AM(UTC)
frigidaire washer won't spin cloths dry (Washer Repair)
by MrVix 1/29/2012 12:17:20 PM(UTC)
Frigidaire Washer won't spin (Washer Repair)
by csnow 12/16/2011 8:06:42 AM(UTC)
by John Mascarena 12/12/2011 12:05:41 PM(UTC)
Frigidaire washer won't spin (Washer Repair)
by maggiemc 11/29/2011 6:39:13 PM(UTC)
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 8/21/2011 10:15:07 AM(UTC)
Frigidaire washer won't spin fast (Washer Repair)
by wiredmonkey 7/6/2011 9:35:37 AM(UTC)
Frigidaire washer won't spin won't drain (Washer Repair)
by janterry 2/16/2011 6:34:44 AM(UTC)
frigidaire washer won't spin out!! (Washer Repair)
by highwaystar 1/27/2010 7:56:47 PM(UTC)
Frigidaire Washer Won't Spin Out (Washer Repair)
by noley99 11/22/2009 7:13:08 AM(UTC)
by stein1960 11/21/2009 12:44:53 PM(UTC)
by maclean 7/28/2009 11:08:42 AM(UTC)
Stackable Kenmore/Frigidaire washer won't spin (Washer Repair)
by sidevinder 5/4/2009 9:48:51 AM(UTC)
by jwes 11/29/2008 4:55:58 AM(UTC)
by cdiscolo 12/25/2007 6:39:58 AM(UTC)
