9 Pages«<6789>
ws6s
#71 Posted : Friday, February 17, 2012 12:50:44 PM(UTC)
ws6s
i did not replace the overtemp thermostat,so do i order both of the parts.
#72 Posted : Friday, February 17, 2012 1:39:10 PM(UTC)
Views messages in topic : 27,455
On December 31 you wrote:
Originally Posted by: ws6s Go to Quoted Post
gene just to make sure of myself.would i remove the overtemp thermostat from the unit to test it while still cold ?
Did you test it for continuity? If you did what was the result?
ws6s
#73 Posted : Friday, February 17, 2012 3:31:38 PM(UTC)
ws6s
im going to test it again,will post results
ws6s
#74 Posted : Friday, February 17, 2012 4:39:56 PM(UTC)
ws6s
so just tested the overtemp thermostat and no continuity,so basically i replaced the main board and the fan for no reason if this is the culprit.what i do notice is the coils are all iced over when running at its 20 -22 degrees.so does that mean the overtemp thermostat is my only issue.
#75 Posted : Sunday, February 19, 2012 2:50:30 PM(UTC)
The very first problem with your refrigerator, reported on December 13, was with the express thaw. The new main control board did fix it (December 22). So it was the reason to replace the main board. Was it?
On December 26 I asked you to check the defrost heater and the overtemperature thermostat for continuity and posted the part number for the overtemperature thermostat. You reply was:
Quote:
...ok thank you gene...
So I assumed you did replace this part and per your reply from January 4th the fridge was working fine.
On January 29th you reported that the fridge is not working properly again. Assuming that the previous problem with the defrost system was fixed, I went on with the further diagnostic.
At this time, based on the information you provided, the overtemperature thermostat maybe the culprit. You did not post any results on the defrost heater test yet.
I absolutely can not diagnose your refrigerator remotely. All my recommendations based on information provided by you.
ws6s
#76 Posted : Sunday, February 19, 2012 6:14:39 PM(UTC)
ws6s
you are correct gene,when i first originally checked the overtemp thermostat i got no reading from it and i guess that is the culprit,anyway thanks .
todd.
#77 Posted : Tuesday, February 21, 2012 1:04:42 PM(UTC)
Hi Todd,
I hope the new overtemperature thermostat will fix it. Keep us posted.
ws6s
#78 Posted : Wednesday, February 22, 2012 4:48:13 AM(UTC)
ws6s
me to gene,me to
Todd
ws6s
#79 Posted : Thursday, February 23, 2012 4:00:29 AM(UTC)
ws6s
unbelievable,
i installed the new overtemp thermostat yesterday and checked the freezer this morning and same situation...
25 degrees in freezer and fan is running.
#80 Posted : Thursday, February 23, 2012 2:24:31 PM(UTC)
How the evaporator coils are covered with frost?
Did you check for continuity the defrost heater?
9 Pages«<6789>
