I have a GE Profile Spaemaker microwave model number JVM1660WB01. This is a over the range model with a vent fan built in. Is the magnetron replaceable? I researched the magnetron and it appears several companies will not sell you the part unless their technician comes out and does the work. The other day smelled a burning smell. I partially removed some of the pannels and could see the connector on the magnetron is black. What parts would need to be replaced on this microwave and how do I get all the way to it to repair? I've attached a couple of photo's of the connector and the unit. Any thoughts on the parts I would need? kauf974 attached the following image(s):
Any thoughts on the parts I would need? Originally Posted by: kauf974 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a GE Profile Spaemaker microwave model number JVM1660WB01. This is a over the range model with a vent fan built in.
Should I repair or replace this unit? Originally Posted by: kauf974 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Any thoughts on the parts I would need?
