jimwhart
#1 Posted : Tuesday, February 14, 2012 9:25:15 AM(UTC)
jimwhart
It freezes, but after a couple of months the frost builds up blocking air from the fan, and while the bottom items stay frozen, those on the top shelves thaw. I believe the defrost heater is not working. What do I need to do? How do I test to make sure it is the defrost heater element that needs to be replaced? Jim Hart
#2 Posted : Wednesday, February 15, 2012 5:32:54 AM(UTC)
Replacement parts for Kenmore 2539280811 | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer (AP5306796) cam till the fans and compressor turn off.
Looks like it is at the back of the unit in the machine compartment.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (AP 2113030) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Here is a problem I cannot find a defrost thermostat so it may be part of the defrost heater assembly. You will have to check with the parts representatives.
It should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
jimwhart
#3 Posted : Wednesday, February 15, 2012 9:46:25 AM(UTC)
jimwhart
Originally Posted by: denman Go to Quoted Post
If yes.
If not on.
Unplug the unit.
If the heater is OK
Thanks Denman. I will try your suggestions. Looks like you have my problem pegged. Thanks again, Jimwhart.
Sears upright freezer (Refrigerator & Freezer Repair)
by daveo50 10/7/2008 4:18:11 PM(UTC)
