Hi Todd, It is possible that the problem is a bad evaporator (freezer) fan motor. If it's bad then it will damage the main control board. I really recommend to order the new fan motor and replace it together with the new main control board. Otherwise the third control board will get damaged again. - The evaporator fan motor Part number: AP3875639
ok gene ordered,
hopefully the fridge will hold on till it arrives.is the fan an easy install ?
thanks todd
You are welcome Todd. The instructions are attached to the reply. Gene.
hey gene i ordered the fan without the thermistor,is that the right one for my unit,
also thanks.
This part number comes up by the model number you posted.
gene got the part and just tore down the freezer and sure enough mine is the one with the thermistor,it figures.guess i will order the thermistor style fan now.:mad:
Todd
Todd,
You can splice in the new motor wires into the old harness.
are you sure i should do that gene\
ok canceling order and splicing
You can but APP would not take it back in case of any alteration.
