Model #: GGF356BBWB Serial #: VF51304980 Hi, I have an older Gibson gas range oven. It has been great but the oven part of the unit does not work any more, as well as the broil function. The burners are still in great working order. I don't know if you have replacement parts for the heating elements, etc? Please let me know your thoughts. I appreciate it. Tim (415) 847-4544 tim@attellpropertymgmt.com
Hi Gene,
thank you for the response.
The oven will not heat whether it is put on Broil or oven functions.
The burners still work great.
I appreciate the parts list but I am not too sure what I am looking for here?
maybe a Thermostat is needed?
How long do those usually last?
Thanks,
tim
Tim,
There are two knobs on the left side of the clock. Make sure the knob on the Stop dial is pressed in while the knob on the Start dial is out. If it's not rotate the Start knob until it pops out.
See if it helped.
