charles e boykin
#1 Posted : Thursday, February 2, 2012 5:24:41 AM(UTC)
charles e boykin
machine won't let hot or cold water in put will spin
sidfink43
#2 Posted : Saturday, February 4, 2012 5:08:19 PM(UTC)
sidfink43
Check to see if 110-20 v is getting to the valve assembly when it is suppossed to fill. If so, the valve assembly is bad. If not, then water level switch or the control unit may be the problem.
washingmachine (Washer Repair)
by realmccoy 10/16/2010 1:52:41 PM(UTC)
Washingmachine (Washer Repair)
by 1joseph 9/9/2009 3:32:09 PM(UTC)
