THERMADOR2004
#1 Posted : Monday, January 16, 2012 12:18:28 PM(UTC)
THERMADOR2004
Error code F34 [FONT='Times New Roman']appeared[/FONT] after 20-30 seconds oven was started and it stops (Thermador single oven model C301 ZS)
Could you advise please what should be done to fix it?
Is it possible to fix by yourself, are you able to provide the schematic drawing with parts location?
Thank You.
#2 Posted : Monday, January 16, 2012 3:47:09 PM(UTC)
The error code "F34" means "The (upper) oven cooling fan air switch not detected".
The problem can be a bad air switch (#3 on the diagram), a bad blower fan motor, a clogged vent line or a broken wires.
The air switch and fan motor can be tested for continuity.
- The air switch Part number: AP2830470
- The fan assembly Part number: AP3858047
Gilbert 19147
#3 Posted : Thursday, February 2, 2012 2:28:57 PM(UTC)
Gilbert 19147
Gene, where is the fan and duct that may need cleaning? How do I access it to do maintenance?
Thanks for your attention.
G
Found it in an online service manual. But it's a project getting the oven out of the cabinet.
#4 Posted : Thursday, February 2, 2012 2:45:01 PM(UTC)
Gilbert,
What is the complete model number of the oven?
Very likely the oven has to be removed from the cabinet.
Gilbert 19147
#5 Posted : Thursday, February 2, 2012 3:16:16 PM(UTC)
Gilbert 19147
Thanks for your reply Gene. I did find the location in an online manual. Getting the oven out is another project.
Appreciate your prompt help Gene.
#6 Posted : Thursday, February 2, 2012 3:18:32 PM(UTC)
You are welcome. It's better to have someone to help you with the oven removal. Good luck and keep us posted.
Guest (5)
