Ice is forming under the freezer drawers . When it gets about 1/4" thick and then melts and leaks out the front . I have checked the ice maker lines on the outside and underneath. There is no sign of moisture in the drain pan which is located under the evaporator fan. Where do I look for the leak next?
The 'drain pan' that is under the evaporator coil in the freezer had a hole in the center that is connected to the defrost drain tube. It is plugged and needs to be cleaned out.
