STS
#1 Posted : 16 years ago
STS
Our Whirlpool fridge started making a fairly loud humming noise a couple days ago. I unplugged the fridge and plugged it back in and it was gone for 12 hours or so but came back. I took the cover off the back of the fridge and found that it's a white fan that I think is vibrating too much.
Anyone deal with this? can I fix it from vibrating some how or do I need to replace it? The fridge works fine but the noise is a bit much.
Thanks in advance
#2 Posted : 16 years ago
What is the complete model number of the refrigerator?
STS
#3 Posted : 16 years ago
STS
The model # is
ED5VHGXMB10
#4 Posted : 16 years ago
Check how stable is the fan mounting frame. Most of the time vibrating is coming from this frame. Check how tight are the fan motor mounting screws.
If there is nothing wrong then replace the fan motor.
- The part number for the condensed fan motor is AP4318657
here are the break down diagrams for the Whirlpool refrigerator Model ED5VHGXMB10
STS
#5 Posted : 16 years ago
STS
Thanks for the help Gene
#6 Posted : 16 years ago
STS
#7 Posted : 16 years ago
STS
The mounting frame is all tight.
The noise is coming from the fan itself, it seems like it kicks on from regular to high speed and when it does that, the plastic fan blade starts vibrating. The fan still works fine but the noise is louder now so I will have to replace it.
GE GSH25JGDD WW making fan noise (Refrigerator & Freezer Repair)
by jmden 3 years ago
Rattling Fan Noise from Kitchen Aid Oven (Oven Repair (including Ranges and Cooktops))
by agdodge4x4 8 years ago
Fan noise on GE Profile Artica? (Refrigerator & Freezer Repair)
by rudybickel 11 years ago
Double oven fan noise (Oven Repair (including Ranges and Cooktops))
by David R. Parker 12 years ago
Evaporator Fan Noise - Fridge 50F (Refrigerator & Freezer Repair)
by trigram 12 years ago
by rossco 12 years ago
Fan Noise (Refrigerator & Freezer Repair)
by wright4s 13 years ago
Evap fan noise? GE SBS (Refrigerator & Freezer Repair)
by Mrdj885 13 years ago
Fan Noise from Evaporator Fan (Refrigerator & Freezer Repair)
by jackw 13 years ago
condenser fan noise. (Refrigerator & Freezer Repair)
by garystarh 14 years ago
Loud fan noise (Oven Repair (including Ranges and Cooktops))
by KeithWC 14 years ago
Condensor Fan noise (Refrigerator & Freezer Repair)
by gtl545 14 years ago
Jenn Air oven fan noise (Oven Repair (including Ranges and Cooktops))
by IreneSN99 14 years ago
GE side by side with freezer fan noise (Refrigerator & Freezer Repair)
by TOPGLOCK 15 years ago
Loud fan noise? (Microwave Repair)
by cfr 16 years ago
