My dryer seems to working fine except there is no heat being generated. The dryer does not get hot at all. Can you tell me what part I need to repair this problem please.
This is a gas dryer correct? If the thermal fuse is bad the dryer will run, but not heat. I would check the thermal fuse first it maybe at fault. I would check it with a multimeter for continuity. It it's bad it will not have any continuity across it's terminals.
Originally Posted by: helenrecord ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My dryer seems to working fine except there is no heat being generated. The dryer does not get hot at all. Can you tell me what part I need to repair this problem please. I PUT IGNITER SWITCH AND GAS COILS ON BUT STILL NO HEAT. ISA GAS CONTROL VALVE THE SAME AS GAS COILS?
